При запуске (уже после успешной установки) в консоли выдает такое:
damir:~/ncalayer/NCALayer$ ./ncalayer.sh --run
-rwxr-xr-x 1 damir damir 11225329 авг 22 12:09 ./ncalayer.sh
damir:~/ncalayer/NCALayer$ #
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x0000000000000003, pid=15293, tid=0x00007cab14abe6c0
# JRE version: OpenJDK Runtime Environment (8.0_422-b06) (build 1.8.0_422-b06)
# Java VM: OpenJDK 64-Bit Server VM (25.422-b06 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C 0x0000000000000003
# Failed to write core dump. Core dumps have been disabled. To enable core dumping, try "ulimit -c unlimited" before starting Java again
# An error report file with more information is saved as:
# /home/damir/ncalayer/NCALayer/hs_err_pid15293.log
# If you would like to submit a bug report, please visit:
# https://bell-sw.com/support
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Файл дампа могу приложить, если потребуется.
По адресу https://127.0.0.1:13579/ никакого ответа нет
В чем может быть проблема?
